Braking Problems, need advice...
Hello all, I have a 99' A6 2.8 with some brake problems. The pedal will drop to the floor if you hold steady pressure on it and my brake light flashes steady, All the pads and rotors are good and I just replaced the master cylinder and blead the entire system and no change at all. Could this be a bad ABS pump? Should the pump make any sounds? (no noise comes from the abs pump now) or could this be a sensor somewhere? Any help would be great...
Anybody around the South Hills area of Pittsburgh, PA with a Vag-com willing to scan my car? I'll bring ya a case of beer for your time (or cash if you prefer)
Thanks,
Jackson
Thanks,
Jackson
Bad ABS would not have the symptons you describe...
Air in line or leak are the usual causes. Check the fluid level then bleed the system to get all the air out. Crawl under the car and look for a leak. You won't see anything on VAG Com
Thanks
Could this be a booster problem or a vac line somwhere?
Originally Posted by Midniteoyl
Sounds like a leak in the brake booster or vac line to it.
No leaks, no fluid loss means either vac leak, or air as stated by NH_USA
Don't bother testing the vac line just replace it. They are the one (and only
) part that is so cheap it's not worth checking. If you want to though I would remove it pressurize it and spray it with soapy water if it bubbles it's done.
foxracing4500
May 9, 2011 04:20 PM
