Cabin Filter - Beware...
Old Feb 11, 2009 | 07:53 PM
auditech79's Avatar
Thats close to the 96, except he doesn't need to remove any torx screws or the wiper blades, other than that its pretty much the same.
Old Feb 11, 2009 | 10:26 PM
a6hcw's Avatar
My 1996 A6 Quattro 2.8L had the spring to the inside air flap break loose. The inside and outside flaps are connected to the same links. The inside air flap can be removed to get at the broken spring anchor and to replace the old vacuum hose for the air flap actuator. The spring anchors at a small hole next to the hole were the vacuum actuator is mounted. The plastic had cracked at this anchor hole and would no longer hold the spring. I fabricated from thin soft copper sheet a bracket that has a hole for the actuator and a hole for the spring. I used aluminum foil to get an impression of the actuator and spring holes and the surounding plastic.
There were a lot of leaves in the bottom of the air box, but I didn't see an air filter.
Old Feb 12, 2009 | 12:59 AM
chefro's Avatar
Good job, McGyver
You know, I was wondering about the lack of a filter, hence the reason I said I coudn't believe the previous owner didn't put one in.
Maybe it really shouldn't have one, but the cabin/pollen filter fit(s) in there as it was meant for that slot!
This makes me think to at least a couple of scenarios:
A) The older (95, 96, 97, X) 2.8L models don't have a cabin filter, even though the slot is there.
B) The older models do have one, and that's indeed where it should go, but the previous owner had no clue of it and never used one (hence the huge amount of leaves build-up)
After reading your post, I must admit a little doubt that I did the right thing by inserting a filter crippled in... In addition, the dreadful bentley (yes, no capital letter...) manual mentions no cabin filter...
So I started googling for a little bit:
1) Look on page 55, for the "Audi A6 (C4) from 1995-1997"
2) Also another source:
3) And yet another source in pdf form which I altered in P-shop:
Even though after looking at these pics it looks like my steps where a little off, at this point I would say that it is safe to put a filter in.
Don' t you?
Old Feb 12, 2009 | 08:57 AM
the G man's Avatar
chefro, do you have any step by step for the C6 HVAC filter change? Thanks
Old Feb 12, 2009 | 12:51 PM
chefro's Avatar
Yes sir, no problem. I pull one out of the hat :
it looks like you have to take the glove box out
Old Feb 12, 2009 | 01:14 PM
the G man's Avatar
Thank chefro, That doesnt look as easy the the C5. Any idea how that side piece comes off, does it just snap off? Do I need to discount the glove box light, CD player and the Ipod interface to drop the glove box?
Old Feb 12, 2009 | 02:05 PM
chefro's Avatar
That dashboard side piece probably comes off the same way as the fuses cover do.
As far as disconnecting your glove box wiring connections, it depends on the length of the wires. I don't know what you have in there, but you may be able to get away with just lowering the glove box without unhooking everything electrical in there.
Old Feb 12, 2009 | 02:56 PM
  #18
the G man's Avatar
I am sorry chefro, I just realize you have a 95 A6. I thought the C6 in your signature was your car
Old Feb 12, 2009 | 09:53 PM
  #19
auditech79's Avatar
Those instructions are wack, you do NOT have to take out the glove box. Do you really think mechanics take out the glove box to change out the pollen filters? Just get under the car and pop down the front panel like i told you and reach up there. Taking off the glove box is way too much work for a pollen filter.
Old Feb 13, 2009 | 12:12 AM
  #20
chefro's Avatar
I don't have a C6 in the signature, and I don't know what are you sorry for.
You asked for C6 instructions and I provided them.
Obviously the MANN people are very misleading. You can surely get under the car. By the time you jack up the car and get under there, probably you would have taken off two glove boxes, not only one.
So, I'm the one who's sorry for passing along erroneous information.
My apology.
