Cabin Filter - Beware...
Old Dec 26, 2010 | 10:57 AM
  #31
bigdadi's Avatar
Changing the cabin filter on my 2002 A6 is much easier. It is behind the firewall, right next to the battery on the passenger side.
Old Aug 21, 2011 | 05:55 PM
  #32
carelm's Avatar
You're right about that. It doesn't even require tools. You just remove the rubber stripping that secures the cover over the rear cowling, remove the cover and you can swap out the cabin filter. While you're there, you can check the low side air conditioning psi if you have the gauge. Total, it's about a five minute job.
Old Jan 28, 2018 | 10:19 PM
  #33
greg_creitz's Avatar
Originally Posted by a6hcw
My 1996 A6 Quattro 2.8L had the spring to the inside air flap break loose. The inside and outside flaps are connected to the same links. The inside air flap can be removed to get at the broken spring anchor and to replace the old vacuum hose for the air flap actuator. The spring anchors at a small hole next to the hole were the vacuum actuator is mounted. The plastic had cracked at this anchor hole and would no longer hold the spring. I fabricated from thin soft copper sheet a bracket that has a hole for the actuator and a hole for the spring. I used aluminum foil to get an impression of the actuator and spring holes and the surounding plastic.
There were a lot of leaves in the bottom of the air box, but I didn't see an air filter.
Do you know what that spring looks like ??
Like roughly how long and diameter ?
Or a Part Number ?
Thanks Greg
503-680-0909
Portland OR
RickA6
Sep 28, 2016 11:19 PM
Kunza
Mar 5, 2012 08:59 PM
elburko91
Mar 22, 2011 07:27 PM
cnelson81
Apr 29, 2006 03:34 AM
PandaXpress
Apr 10, 2005 04:58 AM
