cam, crank seals
Old Mar 9, 2008 | 06:39 PM
LALDEBOT's Avatar
Default cam, crank seals
DOING TIMING BELT REPLACEMENT, CAM, CRANK SEALS LOOK FINE. CAR HAS 120K, SHOULD I REPLACE SEALS AND IS THERE A SPECIAL TOOL FOR REMOVING THEM? AND INSTALLING THEM.
2000 A6 2.7T
Old Mar 10, 2008 | 10:38 AM
Joeski's Avatar
Default RE: cam, crank seals
Cam seals would not be a bad idea since you are in the area. You should check your valve cover gaskets too.
OOOO
mts3
Jan 4, 2011 09:33 PM
dragonrage
Nov 12, 2009 10:10 PM
2005AudiA4
May 31, 2009 09:36 PM
akielb
May 1, 2007 09:49 PM
brewmastr
Jan 28, 2006 10:48 AM
