car will not start
Old Apr 2, 2009 | 12:34 PM
soundguy's Avatar
Default car will not start
'98 a6q 2.8 aha
Drove home from work. No problem or even a clue of a problem.
Car sits for about 1.5 hours. Get in to leave and car won't start.
Here are things I know:
-It turns over
-It has gas -- at least the gas gauge says it does
-I'm not sure if I can hear the fuel pump running when I turn the key on
I did not have enough time to open the hood and listen for the fuel pump.
-I do have vag com but have not checked for codes yet.
Are there any other obvious things I need to check.
Thanks.
Old Apr 2, 2009 | 02:17 PM
chefro's Avatar
Originally Posted by soundguy
-I'm not sure if I can hear the fuel pump running when I turn the key on.
You should be able to hear the pump priming from inside of the car.
Old Apr 7, 2009 | 05:08 PM
soundguy's Avatar
I have finally had a chance to check some things out.
There are no engine codes.
The fuel pump has 4 or so volts at the connector when the key is in the on position.
When I begin to start the car, it goes to 10V
If I jump the pump from the fuse panel, I get 12V at the connector.
I can hear (just barely) the pump when when I jump it from the fuse panel.
I have not checked the spark yet.
I'm not sure it is even a fuel pump issue. That is just where I am beginning.
Any suggestions or clues?
Thanks
Old Apr 8, 2009 | 12:51 AM
djez016's Avatar
icm maybe
Old Apr 10, 2009 | 09:47 AM
soundguy's Avatar
I think I have traced the problem to the fuel pump.
I removed the return line off the fuel rail. Hooked a tube in a container and jumped the pump at the fuse and ....nothing.
Then I gained access to the fuel pump housing under the rear seat, and placed a hose directly to the send port, jumped the fuse and ....nothing again.
I can hear the pump wanting to do something. It kind of sounds like it is trying to spin, but it is hitting something. Like a soft thud.
I was going to remove the pump from the accumulator, but I could not figure it out.
The Bentley manual is too vague.
To remove the fuel pump module (G6), the manual says:
-Release the fuel distributor
-Disconnect return line from distributor
Ok.
To release the distributor, the manual says:
-Attached to accumulator with 3 tabs
-Push toward left to release
It is very hard to see stuff inside the fuel tank.
If I push the distributor to the left, I'm afraid I'm going to break something.
How do I get the fuel pump out?
Thanks.
Old Apr 10, 2009 | 09:59 AM
soundguy's Avatar
One more thing,
After I put the hose directly on the outlet of the pump housing under the seat,
I tried to pull some fuel with my mouth and it was locked up tight.
I could not even pull air.
Is this part of the design of the system... to maintain the pressure,
or is this the sign of a problem?
Chito
Jun 28, 2010 08:48 PM
mark944turbo
Oct 10, 2005 05:51 PM
