Changing Fuel filter
Old Feb 11, 2006 | 09:56 AM
AFJames4's Avatar
Default Changing Fuel filter
i have a 98 2.8L, does anyone know where the fuel filter is and how to change it?
Old Feb 11, 2006 | 11:31 AM
Catterman's Avatar
Default RE: Changing Fuel filter
I think it is under the hood, should be pretty easy to get too.
Old Feb 11, 2006 | 02:16 PM
techbod's Avatar
near the fuel tank under the car
Old Feb 11, 2006 | 03:03 PM
mpw2.7T's Avatar
Default If it's like the '00 2.7T, it's on the right side, ahead of the rear wheel...
Once you actually see it, it's pretty straight forward. I think there is a bracket that has to be removed. The fuel lines attach to the filter using banjo fittings. Make sure you get 4 new crush washers with the filter. And be careful - you will have some fuel spillage. Rags, safety glasses, good ventilation etc., etc. You also might search the forums on AudiWorld.com. Lots of good info and tech articles.
Old Feb 11, 2006 | 05:05 PM
dan908's Avatar
On an A6 it should be under the hood kind of above and toward the back of the air filter. The manual suggests removing your fuel pump fuse and cranking the engine with the fuel pump off/fuse out to remove pressure from the line. Don't put the fuel in the filter back in the tank. Take the whole thing to a household hazardous waste site... there should be one close by and they are usually free.
06a3turbo
Apr 23, 2010 04:16 PM
pointman0853
B7 Models
Nov 26, 2009 07:26 PM
doberman
Nov 4, 2006 01:47 AM
AFJames4
Feb 11, 2006 11:54 AM
brent07
Dec 3, 2005 07:45 PM
