climate control pbm
Old Jun 4, 2006 | 06:20 PM
cmars413's Avatar
Default RE: climate control pbm
Thanks, again!
Old Jun 4, 2006 | 07:12 PM
cmars413's Avatar
OK. No Mas.
I think I found the 3 fuses to which you were referring, but there are no relays above them.
The fuses from left to right are 10, 40 and 50 (amps), but I have no relays above them. Do you happen to know the relay number? All the relays have numbers on them, like "247", or "72".
C
Old Jun 8, 2006 | 03:55 PM
cmars413's Avatar
Finally found the isssue - through giving the car over to the shop (sigh). It took the experts an entire day to track the issue. The wiring diagrams and troubleshooting trees are of no help on this one.
The solution was/is to replace the Solar Panel failover Relay. This is the relay that determines when to let the Solar Panel run the blower motor, and allows the Climate Control Unit to override it when it is turned on. My relay got messed up regarding whether or not to let the blower run from the climate control unit.
I hope this helps
Old Jun 9, 2006 | 01:59 AM
audiSean's Avatar
Sorry for your troubles, but you should take solace in the fact that you may have saved others a lot of headache in dealing with that issue.
AnthonySlaughter
Aug 3, 2014 07:27 PM
a8audiv8
Apr 13, 2007 05:33 PM
cian_ie
Jan 10, 2007 07:07 PM
02A4
Mar 27, 2005 10:42 AM
