Comments on molecular oil additives
Old Apr 16, 2010 | 12:06 PM
nemohm's Avatar
Default Comments on molecular oil additives
I’m wondering if anybody has experienced the “magic” effects of any of the following oil additives:
http://polytron.ca/product_engine_detail.html
Polytron claims “up to 99% wear reduction”.
Intense presence in Eastern Europe (some manufacturing there) – makes me suspicious.
Look s like a pricey stuff…
Lubecorp has a similar product but a way less expensive:
http://www.lubecorp.com/products/pow...nditioner.html
Old Apr 16, 2010 | 01:03 PM
jhuffman's Avatar
Ive seen many different kinds of oil additives on the market, and heard almost as many opinion on their effectiveness. Personally, I used to use one on my 2.8 a4 and didnt have any problems. I think it was called restore and had a kevlar and polymer filler that was supposed to fill in microscopic scratches and cracks in the cylinder and restore engine compression. I never took a compression test before and after so I can't validate its effectiveness but it never gave me problems.
I can say that I've heard that certain additives with cling to the cylinder walls and if the chemical is discontinued or another is used its possible for a reaction to occur which will leave various precipitates which contribute to oil sludge and sedatives.
For my application, I dont think that I induce the kind of stress that would be alleviated from lubricants. Good synthetic 0w-40 at regular intervals with half can of seafoam 100 miles before each oil change is as good as I can see for the 2.7tt.
Old Apr 16, 2010 | 01:19 PM
anthonyz's Avatar
Aftermarket additives are not always a good thing to add to your oil. Some manufactures have been charged by the Federal Trade Commission for false and deceptive advertising. Sometimes additives can be detrimental to the proper function of the oil. Good luck. AnthonyZ tony@zippyoil.com
Old Apr 16, 2010 | 01:47 PM
crazyguy's Avatar
Your comment on precipitates reflects my concern. It's generally not one ingredient that causes harm, but the synergistic effect of two or more ingredients and their interaction that can harm.
Old Apr 17, 2010 | 06:32 AM
jhuffman's Avatar
To put out there when I was working in auto parts I was informed that chemical precepitation is one of the reasons that motor oils as well as other fluids should not be mixed (valvoline with pennzoil etc). Companies each have their own formulas which contain different amounts and types of lubricating minerals and a cross between them can result is alloy precipitates. This is not a hard and fast rule. In a pinch its ok to add a quart of valv to your mobil if your on a road trip and you spring a bad leak. Having enough oil is most essential, but when you get back be sure to change the whole system.
Personally I keep an extra quart in the truck with the tire stuff wrapped and taped in a plastic bag. Just a good idea IMO
diggs
B7 Models
Jun 25, 2011 08:28 PM
ubdevoid
Jan 18, 2011 12:18 PM
beachchair
May 9, 2008 08:10 PM
Jamaha80
Aug 30, 2005 02:23 AM
BFlan
Mar 5, 2005 01:02 AM
