Coolant leak.
Old Sep 25, 2012 | 02:55 PM
AJbuffalo's Avatar
Default Coolant leak.
I recently bought an 01 A6 2.7t and it has a leak. Just replaced the timing belt, water pump, t-stat, and all the r-hoses. Paid $1500 now a hose broke from the pressure. It leads in the engin block and is near the reservoir tank. Can some help me let me know it is and what I should expect to pay.
Old Sep 25, 2012 | 04:24 PM
02A6Beau's Avatar
suppose it all depends on what exactly is broke
try taking it back to the place that you paid to do the timing belt service and tell them the line that busted, went because they didn't properly bleed the system when they refilled the coolant. You took it to a reputable shop that specializes in euro cars, specifically in Audis so they should stand behind their work. You did take it to a specialist, right?
oh, and Willkommen to the forums
good luck
have fun
Old Oct 8, 2012 | 09:03 PM
Boojie_007's Avatar
what do you have to do different with these audi to bleed to coolant?
Old Oct 8, 2012 | 09:53 PM
02A6Beau's Avatar
on our 2.7T there is a bleeder screw on the top of the engine. it is in the front sort of under the driver's side diverter valve. Sort of a fat, flat hex bolt. Takes a 5mm IIRC. I use and extension with a wobble to get on it nice and solid. Its pretty obvious when you see it.
Cioffie
May 19, 2013 10:24 PM
azr3al
Dec 30, 2011 12:37 PM
supacor24
Jun 3, 2011 07:56 AM
inventorA6
Apr 15, 2009 06:46 AM
less_of_me
May 2, 2007 03:29 AM
