coolant warning
Old Apr 4, 2007 | 03:41 PM
atorreon's Avatar
Default coolant warning
my coolant warning continues to turn on. originally the coolant level was a little low but since then has been refilled to the proper levels. the car is now overheating...
Old Apr 4, 2007 | 04:20 PM
2k S4's Avatar
Default RE: coolant warning
So, you are leaking coolant some where, you get the low coolant warning & it's overheating?
You have a problem! My guess is that you still have low coolant, & an air bubble in the system. There is a bleed screw on the right hid side by the throttle body, about 3in in the engine. I would find out where the coolant is going. Hopefully it's just a simple leak (afterrun pump) & not going into the turbo's.
What did you use to refill the system?
Old Apr 4, 2007 | 08:34 PM
wings7351's Avatar
I'm having a hard time locating the bleed screw. Anybody has a picture for it? Mine is a 99 A6 2.8L.
Old Apr 5, 2007 | 02:42 PM
atorreon's Avatar
well now i found out the shop believes its the water pump and timing belt causing the overheating issue...anyone have an idea of how much this should cost?
Old Apr 5, 2007 | 03:41 PM
2k S4's Avatar
ORIGINAL: atorreon
About that much. WE DON'T KNOW WHAT CAR YOU HAVE! Why not ask the shop that diagnosed the problem?
Old Apr 5, 2007 | 04:59 PM
SSn's Avatar
SSn
on the 2.8 it's located near the right timing belt cover I think. It's black metal tube with allen bolt in it.
Personally myself I've never used bleeding screw. All you have to do is fill the car up untill it wount take more. then run at idle until engine warms up then let it cool down and check to see if you can add some more fluid in there. Never had any problems with overheating.
Bleeding is fine, but I don't like antifreeze dripping all over the engine, especially after I hyst cleaned it during t belt replacement.
Old Apr 5, 2007 | 05:31 PM
atorreon's Avatar
sorry fellas....2001 4.2
the shop has confirmed thats its the water pump and belt will be replaced too
Old Apr 6, 2007 | 04:53 PM
Ice Train's Avatar
ORIGINAL: atorreon
I have the exact same car with the exact same problem, how much is it going to run you?
Old Apr 7, 2007 | 12:22 PM
atorreon's Avatar
it's running me a lil more then $800 for the pump and timing belt. i get it back today so i'll update later...
Old Apr 7, 2007 | 10:59 PM
GIAudi's Avatar
If they aredoing all the work make sure they replace the Tstat and all the tensioners/idlers. Better now, than have to re do the stuff. I did a coolant sender as well, just to be safe.
tdoyle
Sep 16, 2009 04:48 PM
03A41.8T
Oct 24, 2007 10:55 PM
golonaus
Sep 25, 2007 09:09 PM
Bartlett
Feb 26, 2007 09:23 PM
memzback
Jan 27, 2007 07:23 PM
