Coolant Warning
Old Jan 26, 2007 | 09:11 PM
memzback's Avatar
Default Coolant Warning
Sometimes when i turn the car on and its really cold it will give me a flashing coolant warning. I turn it off and back on , and the warning disappears. Anyone else have this problem?
Old Jan 26, 2007 | 09:22 PM
XCLR8TT's Avatar
Default RE: Coolant Warning
Yup, the sensors in the expansion tank are likely corroded. You can tape a piece of emory cloth on a screwdriver and try to clean them by opening the tank, then fill the tank up to the full cold level with distilled water.
Old Jan 27, 2007 | 12:10 AM
MeanAudiA6's Avatar
or just get a new one like i did from TTstuff.com it was like 20 shipped
Old Jan 27, 2007 | 04:07 PM
memzback's Avatar
thanks alot for your responses. Do you think it would be covered by my certified pre-owned warranty?
Old Jan 27, 2007 | 04:13 PM
XCLR8TT's Avatar
Yes, it should be. I don't think it is considered a "Wear" part.
Old Jan 27, 2007 | 04:35 PM
memzback's Avatar
Awsome - Ill call my dealership. thanks. Since were on the topic - would replacing my DV and adding a VTDA void that warranty?
Old Jan 27, 2007 | 04:47 PM
XCLR8TT's Avatar
It depends upon how "mod-friendly" your dealer is. If you go with a Forge 007 DV, I don't think they will mind much since it works much like the stock DV other than it is spring based. I kept my stock air box for when I needed to take it to the dealer or in for Smog Testing.
Old Jan 27, 2007 | 04:51 PM
memzback's Avatar
So basically you're saying swap the intake back to the orginal before i take it in? How easy is the install?
Old Jan 27, 2007 | 05:14 PM
XCLR8TT's Avatar
It only takes about 15 minutes to swap it in and out.
Old Jan 27, 2007 | 07:23 PM
memzback's Avatar
Awsome. Thanks so much for all the help.
tdoyle
Sep 16, 2009 04:48 PM
03A41.8T
Oct 24, 2007 10:55 PM
golonaus
Sep 25, 2007 09:09 PM
atorreon
Apr 7, 2007 10:59 PM
Bartlett
Feb 26, 2007 09:23 PM
