Crunching sound when I turn hard
Old Sep 21, 2008 | 11:46 PM
2001A6's Avatar
lol, thats funny, im 18 and my dad says if something breaks, its my fault cause I drive it hard (whatever) so I can pay to fix it. Its probably gonna be front ball joint time soon
Old Sep 21, 2008 | 11:47 PM
auditech79's Avatar
The upper control arms themselves are not the problem, the bushings pressed into the control arms break over time and cause the control arms to move around. When they completely fail the upper links will flop around like a fish out of water since there is nothing holding them still, when you turn the wheel the control arm will bang into the strut housing. When the shop inspects the car tell them to look at the upper control arm bushings and see if they are cracked or flat out blown.
Old Sep 22, 2008 | 01:21 PM
Stone825's Avatar
I'm taking the car in today so I'll update you with what happens. I would drive with it but I just feel like it isn't good to do to the car.
Old Sep 24, 2008 | 05:25 PM
Stone825's Avatar
Update:
It needs new tie rod ends (that was the crunching sound apparently)
Front brakes resurfaced
Wheels rotated (they're doing it for free since its such a small thing).
At least the dealer is paying for the brakes, CV boot, and oil pan when that happened.
Old Sep 25, 2008 | 08:18 AM
davisbr9's Avatar
Member
So, in reading this thread I'm reminded of something...
My Audi makes similar crunching noises (mechanical rubbing of some sort from the front wheel wells) when I turn. It doesn't happen unless I'm making a U-turn or somehow otherwise spinning the wheels all the way left or right. At first I was worried about the bearings, but if that was it I'd feel it when going straight too...
So, I should look at the bushings for the control arms? And CV boots?
Thanks!
Old Sep 26, 2008 | 10:44 PM
Deagle's Avatar
Thanks!
if you're running aftermarket wheels or springs/dampers, you may have tires that are too tall and you're rubbing.
if that's not an issue, CV shafts, hubs, and bearings are goin to be the only things to look at.
Old Sep 27, 2008 | 05:40 AM
MNA6's Avatar
Member
Thanks!
I have the exact same issue. Only here the noise on full turns.
Old Sep 27, 2008 | 11:24 AM
  #18
Bad Justin's Avatar
crunching or clicking or both ...... sharp turns usually indicate a CV problem ..... but don;t rule out other possibilites as mentioned before ....
gfranklin200
B7 Models
Sep 23, 2013 10:11 AM
dlcain
Sep 7, 2009 11:50 AM
BFlan2001
Oct 30, 2007 03:29 PM
IDUA ORTTAUQ 6A
Oct 12, 2007 08:19 PM
sautsinaga
Jan 24, 2007 08:50 PM
