CV Boot Question
Subscribe
Oct 23, 2009 | 11:20 AM
thank you so much for the help Bob.
Average time to complete?
Also, the bolt that goes into the axel, thats a one time torque bolt correct? How much do those cost to replace?
Reply
Oct 23, 2009 | 11:30 AM
nvm, the bolt costs 19. unless I am able to order this part online. anyone know of a good site for this bolt?
Reply
Oct 23, 2009 | 11:35 AM
www.partsgeek.com
www.blauparts.com
www.ecstuning.com
www.autohausaz.com
Reply
Oct 23, 2009 | 06:07 PM
The bolt should have come with the kit, BUT you can reuse yours. After all, they don't come with control arm or bearing kits...
While jackmup recommends going in via the top control arms, be aware that the upper control arm pinch bolt will often corrode into place requiring hours of frustration to drill out. Going via the bottom avoids this potential frustration. And, having done this job both ways, I recommend removing the axle and dealing with the CV joint removal on the bench. Perhaps I haven't learned the secret touch to getting the CV joint off while on the car, but I spent 4 hours on the bitch on the car and five minutes on the one off the car.
YRMV!
Good luck!
Bob
Reply
Oct 23, 2009 | 10:17 PM
The CV joint kit should come with the new axle bolt, circlip, boot, two bands, grease and a few more parts. You will need to buy a CV joint band pliers.
Some of the boot kits do not have enough grease or parts.
The axle bolt should be loosened and tightened with the wheels on the ground, per Bentley.
The car should not be moved once the axle bolt is removed, per Bentley.
Reply
Oct 24, 2009 | 12:10 AM
I have heard those bolts are a bitch. So keep in mind I'm in Florida with two Florida cars. These cars have not experienced road salt. So all my bolts come right out. I just did my control arms and not one bolt was frozen. So if that is the case Bob's way might be the easier way. Your going to have to print this stuff out and figure out the best way when you get in there.
spray them down with Liquid wrench a week in advance.
Reply
Nov 4, 2009 | 02:34 PM
How many flat-rate hours does an independent shop charge for 1 side front outer CV boot?
thanks
Reply
Nov 5, 2009 | 08:20 AM
  #18
2.5 hours per the book. So at $75 an hour, $200 or so is a fair price.
Keep in mind those are after tax dollars. Depending on your tax bracket, you would need to earn $250 to $300 or more to pay someone else to do this repair. How long does it take you to earn this amount of money? Chances are you can "earn" this in less time (and "learn" something in the process) by doing the job yourself. And, Autozone and etc. all loan tools so there are very few you would actually need to buy.
Bob
Reply
Subscribe
