Question about cv boot repair
Old May 10, 2008 | 02:33 PM
bsharp8's Avatar
Default Question about cv boot repair
I am replacing a torn outer cv boot and I lost the plastic washer that was on the axle. The new boot kit I bought has a metal washer but the write-ups I've seen looks like they have both washers. Do I need both? If so, anyone know if they can be purchased separetly.
Thanks, William
Old May 11, 2008 | 11:50 AM
a6hcw's Avatar
Default RE: Question about cv boot repair
You need to go to the Audi parts department and buy the plastic spacer washer. Also, you need to replace the spring steel wire circlip, as they get damaged when separating the shaft from the outer CV joint, with tool 3207. These small parts are usually loose inan unsealed box, so sometimes they are missing. Your kit should also include a new large M16 washer bolt.
Old May 11, 2008 | 08:06 PM
bsharp8's Avatar
Thank you sir. I bought a new cv boot kit and it came with everything except the plastic washer. I'll check with the dealer tomorrow.
William
bbud
Sep 26, 2010 04:20 PM
jaymac
Jul 26, 2009 07:24 PM
AR15Texan
Jan 23, 2009 01:34 AM
GRIDLOCK
Sep 11, 2007 12:04 PM
Victo_Peru
Sep 23, 2006 01:18 PM
