Dash turn signal indicator
Old May 4, 2009 | 11:26 AM
danstr1's Avatar
Default Dash turn signal indicator
The left turn signal indicator on my dash recently went out. I still works but is very, very faint and not visible in the sun. The turn signals continue to work etc and I can hear the audible click of the turn signal working. Minor incovenience but wasn't sure what would be entailed if I wanted to replace the bulb? Or whether it's possible?
Old May 4, 2009 | 06:29 PM
NH_USA's Avatar
the buklb can be replaced, but you need totell us what year you have for instructions.
Old Oct 27, 2011 | 07:39 AM
2.7t6spd's Avatar
Default please help
i have this exact same problem in my 2000 a6. but i don't even think mines lights up at all. its very frustrating cause i always forget to turn it off when i change lanes. thanks in advance for your help
Old Nov 8, 2011 | 03:24 PM
2.7t6spd's Avatar
Default no takers?
anybody else have this issue? is it difficult to replace the bulb?
Old Nov 24, 2011 | 07:34 PM
hilld's Avatar
I am afraid there is no bulb to replace, at least not on my 2002 S6 (basically the same instrument cluster as an A6). I took my cluster apart today for exactly the same reason, a dim left indicator arrow, every once in a while it will be full brightness. There are no bulbs in there, it is all LED's that are soldered to the board and I am not sure were I would be able to find such an LED. The cheapest solution I have found is to send it to many of the places that rebuild the instrument clusters, I will probably call first, but since it is Thanksgiving, I will have to wait until next week before I call.
Hope that helps a little.
Derek
dbelcher
Nov 18, 2011 04:18 PM
jcd144s
Jul 14, 2009 08:48 PM
jcd144s
sheldon
Jul 2, 2009 12:14 AM
rawburt
May 9, 2008 06:07 PM
