Dashboard Clusted display
The Cluster display in my 1999 a6 Q whent bad, is hard to read what the computer is telling and if I used select speed mode I have to kind of guess in that gear I am running, I have been told that is a common issue in Audis and that I shuold get a complete dashboard and replaced, around two hours work mechanic time.
I am surprice that nobody in this forum has the same problems, I know of two other Audi owner with the same issue.
Is there a solution for this? any comments that can help?
Thanks
Thanks
ORIGINAL: Danielm
Thanks
Thanks
Keep it post it, so I can try the same, can't believe that the only solution is to replace it, a friend of mine who is an electronic guy told me he should be able to fix it as well, pitty just move out of hte country.
