dashboard indication
Old Aug 14, 2009 | 04:10 PM
xewax's Avatar
Member
Default dashboard indication
How can I change kilometers, Lets say i see 150000 km and i want to make 100000km. How is it possible to do that with vagcom? I just want to reduce numbers. And how to check that it has been changed.?
And lets say my airbags light is on on the dashboard. How to turn it off? If i turn it off on the dashboard so my airbags will work. right?
Old Aug 14, 2009 | 05:20 PM
Jackmup's Avatar
In order to change the KM you need to buy a new ECM or reflash it and pay someone to lie and reprogram the wrong km into it. These vehicle are designed to keep people from lying and changing the odometer readings.
Your airbag light will go out when you fix the problem that's for sure. Or you can alter the light but the reason it's on is because the sensor is broken and that means it will not deploy in an accident.
Why not just leave them alone and let the new owner know they are broken so they can have them repaired?
Old Aug 15, 2009 | 01:08 AM
xewax's Avatar
Member
What is ECM? And how to reflash it?
I just want to know how to reprogram it. I just want to know how to do that not to lie someone.
Talking about airbags My friend told me that if i fix it (turn the light off) the airbags will be repaired. Airbags are not broken but the only thing i need to do is to turn the light off the dashboard to make them work.
Old Aug 15, 2009 | 02:22 AM
m000035's Avatar
Changing the odometer reading is not legal in most places. If you have a Brand NEW speedometer, it can be rolled forward to match your cars milage... one time only. Getting a USED speedometer to work in a different car is "do-able" but is a PITA. They did this to keep people from "rolling back" the milage to increase the value of a car. (Changing the milage for resale is fraud.)
You need to know why the Airbag light is on to know if reseting it will "fix" the problem. If it is on due to one of the air bags had been disconnected and reconnected (like the one in the steering wheel) resetting the light will "fix" the problem. If you do not know why the light came on, It isn't a good idea to just reset it. You'll need a VAG-Comm in eather case.
Old Aug 17, 2009 | 08:19 AM
xewax's Avatar
Member
Thank you about the airbags.
C'mon guys, I don't want to change the readings, I just want to know how to do that. And i also want to know how to find out if it has been changed.
Old Aug 17, 2009 | 12:31 PM
hxgaser's Avatar
There are some software/hardware package that you can buy from overseas. Do some search and motronic ECU programming, which also relates to eprom read and write. The reason that I am saying do search in ecu is that the odometer information is stored in ECU depending on the model.
BTW, we all know what you are trying to do. No wonder that I don't trust this humanity. >
Old Aug 17, 2009 | 12:38 PM
Midniteoyl's Avatar
Take it to a dealer.. Vag-Com wont do it.
Old Aug 17, 2009 | 12:44 PM
NH_USA's Avatar
hxgaser said it all --
Old Aug 17, 2009 | 12:50 PM
AutoUnionFan's Avatar
he doesnt want to change it, he just wants to know how to change it
shady people = FAIL
Old Aug 17, 2009 | 12:55 PM
NH_USA's Avatar
Cool OH?
I guess I missed that part!
