Engine clatter at start up
Old Oct 20, 2008 | 08:07 PM
jrseaman's Avatar
Default Engine clatter at start up
Just bought an '03 A6 Avant with 67K miles. Seemed to be in good shape - no nicks or dents; clean interior; clean CARFAX, etc., etc.. Runs very well getting 24 mpg at about 75 mph.
Problem: On start up, after sitting overnight, for about 3 - 4 seconds there is quite a lot of clatter in the engine. It does not sound exactly like lifter noise like the 5 cyl motors, and it stops apparently when oil gets to whatever is making the noise. I changed oil and filter (5w-30) and first thing this morning it seems even worse.
What is it and is there a fix?
Thanks,
Old Oct 20, 2008 | 08:50 PM
james0013's Avatar
for what it is worth here is my 2c. It could be the valve chain tentioner. mine (2000 2.7t with 77500 mi) will give a metalic rattling sometimes after start up. It only lasts for a few seconds and then goes away. The problem is that the oil pressure is at its lowest when started in the morning and it rattles untill the pressure builds up. not sure if it is a problem but things are ok with it for now.
Old Oct 21, 2008 | 01:00 PM
Deagle's Avatar
good to know I'm not the only one hearing this.
I hate clatter.
I'm running Amsoil 5w40 Euro Synthetic and a Mann filter.
I just open the garage at the same time I start the car so I don't have to hear it and worry. lol
it definitely quiets down after the first 2-3seconds though.
00 2.7t-tip @ 87,000 miles
all preventative maint done.
Old Oct 22, 2008 | 12:51 AM
auditech79's Avatar
Chatter noise is normal for the 3.0L engine, its just a lack of oil in the cam tensioners.
2.7T motors chatter a lot less, but tend to do it more often with full synthetic oils.
Old Oct 22, 2008 | 07:58 AM
Khardysius's Avatar
My 4.2 does the same thing. I do have a minor valve cover leak that I still need to get fixed, but not so sure this is related.
Old Oct 27, 2008 | 08:31 AM
jrseaman's Avatar
Default engine clatter
Thanks for the input guys. At least I know it's not a problem peculiar to my car. Guess I won't worry too much about it unless performance problems develop.
Old Oct 27, 2008 | 11:50 AM
paulb's Avatar
Member
You guys answered my question also....I wondered about this with my 3.0 a6 avant. I figured it was nothing major.Mine also only occurs after a cold start and lasts for maybe 2 seconds
Old Oct 27, 2008 | 11:55 AM
afstud6900's Avatar
Banned
my 99 a6 2.8Q with 180k miles does the exact same thing, i was told by the stealership that this is ok.
kroogz
Jan 20, 2015 06:09 AM
blakesmithrx785
Feb 4, 2012 04:18 PM
TurboRingz02
Apr 14, 2009 10:20 AM
CABNER
May 5, 2008 07:33 PM
Jayo
Jun 25, 2005 10:48 PM
