(help)ENGINE WILL NOT START
Old Apr 18, 2008 | 08:09 AM
CABNER's Avatar
Default (help)ENGINE WILL NOT START
driving the other day, when engine quit. I costed into the driveway.My first thought was that the timing belt broke.. Well when i got to my timeing belt, it wasn't broke, it was missing about half of the teeth. SO got new belt on and 99 % sure engine was at TDC. Tried to start before putting everything back together(pulleys,belts,etc..) So we turned the key and the engine just cranked..
We stuck a piece of hard plastic tubing in the #1 cylinder and marked when the cylinder was at the top and the marks were lined up at tdc. I am totally lost now. Please help.... I hope it is something simple,,it usually is.
Old Apr 18, 2008 | 10:03 AM
CRAZYHAWK's Avatar
Default RE: (help)ENGINE WILL NOT START
Have codes read and post them.
Old Apr 26, 2008 | 12:23 PM
AudiTech616's Avatar
MODEL, YEAR, ENGINE???
Old May 4, 2008 | 03:13 AM
manin59's Avatar
There is no difference if the belt breaks of looses teeth. It results in engine damage (the valves get bent by the pistons. Check pressure in the cylinders, and you will know.
Old May 5, 2008 | 07:33 PM
tHe kNiGHt FaLL's Avatar
pull the intake manifold off and check the valves
adamwells
Mar 15, 2012 04:05 PM
TurboRingz02
Apr 14, 2009 10:20 AM
alas
Mar 26, 2007 07:57 PM
ambriz81
Jun 29, 2005 09:04 PM
Jayo
Jun 25, 2005 10:48 PM
