Engine squeaking
Old May 4, 2010 | 09:12 PM
sf_dan's Avatar
Default Engine squeaking
Just wondering if anyone has ever heard their engine sound like mine.
http://www.youtube.com/watch?v=2xadGMQMyo0
My mechanic thinks it might be the water pump.
It does not mater if a/c is on or off.
Old May 5, 2010 | 12:12 AM
Jeffla's Avatar
I would have it fixed ASAP if it is indeed your water pump. For sure it is a bad bearing on something, but what is the question.
Best of luck and welcome to the forums.
Jeff
Old May 5, 2010 | 11:07 AM
NH_USA's Avatar
Either the WP or a TB tensioner. In any case get it fixed yesterday because a failure could blow the TB and you'll be in for big dollars. While you have it apart do the TB jig -- WP, tensioners, thermostat, front seals etc. Check Blauparts for the kit.
Old May 5, 2010 | 05:59 PM
sf_dan's Avatar
Thank you for the reply and confirming that is its the pump and or tensioners. Makes me feel better before dropping all that $.
Old May 5, 2010 | 06:15 PM
ppgoal's Avatar
If you have over 70k miles, it's not a waste of money to replace the TB, WP, and all the odds and ends like recommended. If they seize up and stop the TB, your pistons and valves meet which is very bad and expensive.
Old May 6, 2010 | 10:21 AM
NH_USA's Avatar
Don't waste your time trying to figure out if it is the pump or tensioner do the whole job now! As PPgoal said a failure is bad and will cost BIG dollars.
mhellman
Sep 21, 2009 09:53 PM
andrewj654321
Dec 19, 2008 01:31 AM
1.84life
May 27, 2008 08:36 PM
btunfounded23
Dec 4, 2007 02:10 PM
knyks342
Jul 25, 2007 01:14 AM
