windows squeaking
Old Jul 24, 2007 | 11:56 PM
knyks342's Avatar
Default windows squeaking
Ok so all of my windows are squeaking when they roll down....i did a search and found a little about it....my thing is i know i need to put the silicon on the window ...juts dont know where....do i put it inside the trim around the window or do i need to take the door out and put it somewhere in there....can i just spray some stuff into the door?...any help would be greatly appreciated.
thanks
Old Jul 25, 2007 | 12:00 AM
auditech79's Avatar
Default RE: windows squeaking
Don't spray silicone on your directly on your windows, it never comes off.
Only spray it in the channels on each side of the window.
Old Jul 25, 2007 | 12:02 AM
01A4T's Avatar
I have never had this problem on an Audi, but I used to own a mustang gt, and i sprayed some wd40 near the bottom window corners, or you could try spraying with the windows up in the bottom corners. Worst case, the window trim has lost most of the felt surface and you can replace them, and there should be no noise. the noise is most likely caused by the wear of the rubber trim/felt, and it is squeeking because it is only rubber to glass.........
Old Jul 25, 2007 | 12:05 AM
auditech79's Avatar
ORIGINAL: 01A4T
No its actually pretty common, a little lube takes the noise right away though.
Old Jul 25, 2007 | 12:22 AM
01A4T's Avatar
wouldn't you think it's the rubber/felt trim wearing away creating the sqeak in the corner?
Old Jul 25, 2007 | 12:30 AM
whytap109's Avatar
where do you put the lube at ????
Old Jul 25, 2007 | 12:37 AM
auditech79's Avatar
ORIGINAL: 01A4T
No, our windows only use felt between the glass not all the way around, it rides on rubber, so when it dries up it screams like all hell.
As for where you put the lube..... you see when you roll the window up and down right? Spray the lube in the guides on each side of the glass when the window is rolled down so it doesn't get on the glass.
Old Jul 25, 2007 | 12:54 AM
01A4T's Avatar
ah, i did not know that....good info to know, thanks.
Old Jul 25, 2007 | 01:14 AM
AteUrV8's Avatar
dam auditech is a good member to have around, straight up audi tech, ballin.
al1d8gun
Jun 14, 2013 07:37 AM
sf_dan
May 6, 2010 10:21 AM
kchao2000
Sep 22, 2009 03:42 PM
striker451
Sep 4, 2009 03:44 PM
andrewj654321
Dec 19, 2008 01:31 AM
