Extreme Boost Problem
Old Apr 27, 2007 | 03:48 AM
ahbrit's Avatar
Member
Default Extreme Boost Problem
I've had my 2.7T for about 3 months. i had the REVO software installed which is supposed to give me about 318hp. Well today i got a boost gauge installed (why arent they factory fitted?) and found i'm running at 25lbs boost at full throttle. Isn't that dangerously high? what could be wrong? And yes, it's rediculously fast, the tyres almost light up when the charge kicks in.
I've installed decent Diverter valves about 2 weeks ago.
Old Apr 27, 2007 | 12:40 PM
Joeski's Avatar
Default RE: Extreme Boost Problem
I can tell you that I have the GIAC chip in my car. My turbos are boosting around 21lbs. I do not know much about REVO though. My suggestions are to call REVO.
Old Apr 27, 2007 | 04:03 PM
rawkdahawdcore's Avatar
it's only dangerously high if the compression is super high. or if you keep it across the powerband, which i think is pretty much impossible with the stock turbos. i'm not sure what the compression is though...i thought i read somewhere that it was like 11:1 or something...which is high.
Old Apr 28, 2007 | 03:45 PM
ahbrit's Avatar
Member
It stays high across the powerband until 3rd gear, then it goes down to about 22lbs. i have no idea how high the compression is though.
Old Apr 28, 2007 | 09:13 PM
formulagigi's Avatar
that is extremely high, do you have ko4's?
Old Apr 29, 2007 | 12:48 AM
ahbrit's Avatar
Member
doubtful on the K04's.
Old Apr 30, 2007 | 02:32 PM
votblindub's Avatar
I'd call Revo. I was thinking about getting that chip into mine and then i went with APR because of how smooth it is. I didnt want a super agressive chip. That much boost seems a tad high. Maybe you need to get a boost controller and keep it lowered.
Old Apr 30, 2007 | 04:50 PM
2k S4's Avatar
ORIGINAL: Joeski
What GIAC flash do you have? None of the K03 codes should go that high, maybe a slight spike, but you should be close to 16-18psi (depending on air temp, altitude, & where you tapped the gauge feed).
I would LOVE to see some Vag-Com logs of block 115.
Back to the REVO, YES, it's SUPER bad for the turbo's, you are over spooling them, anything over 20psi is in very dangerous over spooling. Since it's Revo, you might just want to turn the boost down with Revo's Lemi tweaks. Again, you should log block 115 with vag-com & make sure the car is requesting that much boost.
If it's not, you may have a bad N75, sticky wastegate, or a boost leak some where.
My car with the latest GIAC code, spikes around 17psi, & tapers around 15ish PSI.
Old May 3, 2007 | 10:31 PM
ppgoal's Avatar
What kind of boost gauge and where did you get it? How difficult was it to install? Cost? I'd like to have one to keep an eye on my turbos.
Old May 4, 2007 | 03:39 AM
ahbrit's Avatar
Member
i am unsure of the brand of gauge. I think any would work. I got professional installation from a mod shop (1 hour)
Gauge = $40
Pod = $17
Install = $60
$117
a4intec
Oct 27, 2006 03:43 PM
d5coupe
Jul 26, 2006 03:25 AM
d5coupe
Jul 18, 2006 05:24 PM
d5coupe
Jul 17, 2006 11:46 AM
eurotech
Apr 5, 2006 02:18 AM
