fluid help
Old Jun 19, 2008 | 03:44 PM
mirov0's Avatar
Default fluid help
I feel really stupid for asking this but I did not get an owners manual with my 2.7t and I just got it not too long ago. But what kind of fluid is the very top container when you pop the hood? Its a red liquid and almost feels like water to me. It is under the minimum so I need to figure out what it is and if i need to get a specific audi kind. I really appreciate the help guys
Old Jun 19, 2008 | 03:58 PM
oc_audica's Avatar
Default RE: fluid help
brake fluid
Old Jun 19, 2008 | 06:39 PM
ericgl's Avatar
Coolant.
Old Jun 19, 2008 | 06:41 PM
hxgaser's Avatar
Coolant. G12 spec which is used by VW and Audi. If you pour normal green coolant into the container, it will turn the entire cooling system into a gel. So don't do it. FYI, a gallon of G12 from Audi is about $22. I think you can get them cheaper at VW dealership.
Old Jun 20, 2008 | 04:26 PM
mirov0's Avatar
good to know, thanks a lot guys I love this website and how everyone can answer peoples questions without making fun of them.
Old Jun 20, 2008 | 06:34 PM
ericgl's Avatar
If you're down just a little (like a pint) it is OK to top off with distilled water. Then try to get some Audi/VW 50-50 coolant for top offs.
Old Jun 21, 2008 | 02:15 AM
ming4.2's Avatar
use waterwetter. its the shiet. you can get it at a lot of places.
Old Jun 21, 2008 | 10:16 PM
gmatov's Avatar
hxgaser,
I assume you are saying topping off the Audi coolant with green coolant will turn it to gel, not that a system with JUST green in it will gel up or eat the rad or something.
Just had my rad replaced, they filled it with green, so think I am safe. Giving this 90 100 to one of my kids.
Cheers,
George
Old Jun 22, 2008 | 08:03 PM
hxgaser's Avatar
George,
As long as all residual fluid was drained and flushed out, I don't see a problem with using conventional coolant. As you noted, G12 and conventional coolant, when mixed, turn into gel.
Anyways, 1990 100 should be conventional green coolant anyways. VAG started to use G12 starting on 1997 I think. You should be alright.
MartinCieslak1
Feb 25, 2011 07:51 AM
konabiker47
Jan 20, 2009 09:28 PM
