FOG LAMPS & More
Old Aug 11, 2006 | 05:31 AM
Digicool1's Avatar
Default FOG LAMPS & More
Hey I was wondering how i could turn on my fog lamps for the 2001 Audi A6 and also what the two switches on the inside driver's side door sill are. When you open the door, there are two buttons, one with a car that has a beam like this ))). Also, if anyone could help me carfax another audi i am about to buy, id appreciate it. You could PM me or email me at Digicool1@aol.com. Thanks in advance
Dela G
Old Aug 11, 2006 | 12:18 PM
SouthboroAudiGuy's Avatar
Default RE: FOG LAMPS & More
Dela,
Fog lamps are turned on by pulling the light switch toward you. One pull turns on the front; two pulls turn on the rear. There's even a great little mod out there (info here) that lets you turn them on without the headlights being on at the same time. Many people do this to have daytime running lights that reduce wear on the expensive Xenons.
The two buttons on the driver's B pillar are the remove trunk release and the motion sensor deactivation. The former is self-explanatory. The latter deactivates the interior motion sensor for the alarm system. Useful if you want to set the alarm on your car with a dog inside/windows open.
I'd back off on the request to get somebody else to do a carfax for you. Not legal and likely to get your post deleted by the forum moderator.
Old Aug 11, 2006 | 01:18 PM
Boston Driver's Avatar
One word of caution about the fog lamp rewire "mod" is to make sure that you inspect the wires every now and then. If you run the fogs for an extended period of time, the wire can get VERY hot and burn out, even melting the plastic near the wire before blowing a fuse. I removed mine from the 4.2, but it worked very well in my 2.7T.
Oh, and in case you have not yet found it, look for your owners manual under the steering column. There is a handy little slot there for the manual booklet.
Old Aug 11, 2006 | 05:02 PM
Digicool1's Avatar
Hey thanks guys, and yea i feel like a moron since i just found my owners manual under the column. Haha im such an audi noob. Thanks guys
ben721364
Aug 27, 2012 03:36 AM
chebert69
Jun 22, 2010 01:13 PM
secmil
May 26, 2007 10:55 AM
AudiOso
Mar 16, 2007 09:15 PM
slvrs4
Jun 15, 2006 11:01 PM
