Front wheel bearing replacement
Old Dec 4, 2010 | 03:44 AM
Naudi1's Avatar
Default Front wheel bearing replacement
I have a 1995 A6 quattro with the 2.8 liter V6 and I want to replace the front wheel bearings, are these pressed in and out with a hydraulic press or are they just a press fit by hand (hamer)?
Old Dec 4, 2010 | 09:55 PM
bob martin's Avatar
Real press, but in a pinch, a hammer will work. Use a block of wood to soften the blows.
Old Dec 5, 2010 | 07:59 AM
ManyAudis's Avatar
I did both of them in my 1995 and a press was definitely needed. Maybe if the car was only years old a hammer would work but that bearing has been in there 15 years. I used a friends 20 ton press and even then we had to heat the housing.
Old Dec 5, 2010 | 10:03 AM
Theiceman's Avatar
i have a 95 Audi 90 and did this .. forget the ' on the car" tools .. they are useless . asmentioned I actually bough a press for this as it still worked out cheaper but they were a nightmare to get in and out
I borromed a hub shark kit form the tool store to use as tools for the press but it was a tough process.
Keep in mind if the hub comes off the car you will probably need an alignment when your done.
Old Dec 5, 2010 | 12:05 PM
chefro's Avatar
+++++++ 1
Old Dec 5, 2010 | 12:32 PM
gwos25's Avatar
The one time I did front wheel bearings, I also needed a press. I removed the hubs from the car myself, and dropped them off at a shop to be pressed out and in.
Gary
green2man0
Oct 5, 2014 02:19 PM
ChillyWilly
Apr 26, 2009 01:02 AM
ImTheDevil
Mar 8, 2008 03:40 PM
chitownA4
Sep 14, 2006 12:18 AM
blackA4
Jan 30, 2006 03:12 PM
