Got a poppin goin on.
Old Nov 10, 2009 | 08:36 PM
jaceefis's Avatar
Default Got a poppin goin on.
A6 2.8 started popping and I think it maybe the vacumm system.Back firing through the exhaste comes on even more when the A/C is on. I have changed out some of the vacumm lines. Can a purge valve be cleaned and reused. Just was wondering.
Old Nov 10, 2009 | 11:26 PM
Jackmup's Avatar
Timing
Try pulling codes and checking the cam position sensors and timing belt.
See if you have a P0300-6 the last number is the cyl maybe you have a messed up coil or ICU.
Old Nov 11, 2009 | 10:53 PM
jaceefis's Avatar
Default Still at it
Well it's not the coil pack, also cleaned the purge valve and replaced all the vacumm lines. I will keep lookin or it's off to a good shop.
Old Nov 12, 2009 | 12:31 AM
auditech79's Avatar
If its popping out the exhaust its not "backfiring" Its got more of a hicupp, too much or not enough fuel. DO you have a vag com? What does the long term fuel trim say in data block 32?
Old Nov 12, 2009 | 05:40 PM
jaceefis's Avatar
Default Still not rtght
Don't have a Vagcom yet (so if there is anyone around Houston that has one there's a cold beer in it fir them). I did stop at Auto Zone and the P0301 code came up. Missfire on #1 cyl. Going home to read the spark plug to see just how they look. Check out the plug wire and all this. More later.Thanks for the help...
incrementalg
Jan 16, 2010 08:43 PM
sakuraba
Apr 2, 2008 11:42 PM
Notahondaowner
Mar 15, 2008 03:30 PM
xav6ier
Mar 13, 2007 08:31 PM
