Hard Start after sitiing 1 hour plus
Old Aug 29, 2013 | 02:37 PM
richie70's Avatar
Default Hard Start after sitiing 1 hour plus
I have a 2005 Allroad 2.7T and the car starts right up first start. doesn't make any difference what time of day. If the car sits for about 1 hour or more it takes quite a few cranks before it will start. It does not indicate any codes when checked with Vag-Com. I did replace the CTS on chance this was the problem but it didn't fix the problem. I have checked the fuel pressure and check for bleeding injectors but all of it checks good per specs.
Is this maybe a fuel pump problem?
Old Aug 29, 2013 | 03:18 PM
Nebuchadnezzar's Avatar
This maybe a long shot, but have you tried cleaning your MAF?
Old Aug 30, 2013 | 11:09 AM
richie70's Avatar
No but I will try that and post results.
Thanks.
Old Sep 11, 2013 | 10:30 AM
richie70's Avatar
Cleaned the MAF and this did not fix the issue of starting.
Looking into replaceing the Crankshaft Position Sensor.
Old Sep 23, 2013 | 06:18 PM
richie70's Avatar
Installed new wires and plug on CTS and tried new Crankshaft Position Sensor. Neither fixed the hard start when hot.
Anybody got suggestions as to what maybe the problem???
Old Oct 15, 2013 | 01:37 PM
bsmith's Avatar
Default same issue...
I'm interested in the resolution cuz I just purchased a 2000 A6 4.2 and has same problem. Seems not to be getting fuel after it's warm.
Old Oct 16, 2013 | 08:19 PM
richie70's Avatar
Still haven't solved the issue. My Allroad is a 2.7T.
Old Aug 8, 2015 | 07:19 AM
vantheman's Avatar
I have the same problem, but the other way round.when i turn the key the glow plug light goes out straight away,and the car starts after about 8 seconds later.
but once it has started i have on problem starting it. i have a 2002 A6 allroad.can anyone help with this problem.
vantheman.
rccks96
Aug 29, 2023 08:58 PM
Audi Forums Editor
Jan 28, 2013 05:08 PM
cmbcannon
Aug 24, 2008 12:09 AM
wings7351
Jun 6, 2007 09:52 PM
shift
Feb 1, 2006 02:22 AM
