has anyone replaced a valve cover gasket?
Old Dec 22, 2005 | 09:22 PM
chaz2.7t's Avatar
Default has anyone replaced a valve cover gasket?
any help please
Old Dec 23, 2005 | 02:23 PM
chaz2.7t's Avatar
Default RE: has anyone replaced a valve cover gasket?
no one has experience in doing this?
Old Dec 24, 2005 | 04:14 PM
heisse_mkII's Avatar
try audiworld.com
Old Dec 25, 2005 | 02:53 AM
AudiTech04's Avatar
What exactly are you wanting to know
Pretty simple procedure really just remove the 10mm nuts holding it on
When putting on the new gasket be sure to silicone the corners
Old Jan 19, 2006 | 12:29 AM
chaz2.7t's Avatar
do you get to them from the top or bottom?
Old Jan 31, 2006 | 06:25 PM
chaz2.7t's Avatar
is it pretty simple to get to or must you remove anything else.the audi dealer said that when you do the valve cover you need to do chain tensioner?
Old Feb 4, 2006 | 07:28 PM
dankhound's Avatar
If you have a 2.7 youll have to remove some intake pipeing. Otherwise its as simple as auditech said. You definatly do it from the top. Are you sure the valvecover gaskets are leaking and its not the cam adjuster gaskets. The only chain im aware of is tensioned by the cam adjuster. If those gaskets are leaking you will have to remove chain tension using a special tool. Then you will be able to slide the cam adjuster gasket seals in. I wouldnt try it without removing the cams thou.
Old Feb 12, 2006 | 03:26 PM
steviejayvaughan's Avatar
whenever we do cam adjuster gaskets/seals we never remove the cams. its a waste of time and can be easily done with the special tool to compress the tensioner. all you need is various shaped picks to lift the gasket up over little dowels for the holes. then remove the half moon rubber seal. there a definite must if doing the valve cover gasket.
IPStevieB
Aug 26, 2013 09:03 AM
foxracing4500
Feb 20, 2011 06:33 PM
chickeneater
Dec 18, 2010 02:53 PM
robert.jones
Dec 10, 2008 08:01 AM
robert.jones
Dec 10, 2008 07:56 AM
