Havin a problem
Old Dec 9, 2007 | 07:58 PM
Fast3.0a6's Avatar
Default Havin a problem
i recently just bought my 3.0a6,its been bout 2 weeks so far.before i bought the car i tested every thing with the car lights,windows,etc.everythin good.now i realize that when i tried to roll down the back drivers window it jumps up an down then roll up so slow or it get stuck. i have a warranty still active so im bring it to the dealer tomorow.i'm heated.[:@].the car other than that is crazy,wouldn't change nothin.but what would cause that?
Old Dec 9, 2007 | 08:08 PM
auditech79's Avatar
Default RE: Havin a problem
The window regulator clips are broken more than likely, they are made of plastic and the cable breaks its way through them. Its a common problem on the A4 and A6 so don't be surprised if it happens again to another window down the road. The good news is the front window clips can be replaced by themselves which only cost $5 at www.ecstuning.com
The rear windows you have to bite the bullet unforuntately.
Old Dec 9, 2007 | 11:12 PM
Fast3.0a6's Avatar
thanx, i should be able to get it fixed cuz i still have an active warranty
Old Dec 10, 2007 | 04:11 PM
CodyR's Avatar
Just on a side note. I had that problem with my front passanger side window and my mechanic sprayed silicone lubricant in the tracks and around the window. Didnt work right away but it must have losened something up once it worked its way in. The window works fine now.
jimc137
Mar 9, 2011 06:48 PM
skoks21
Aug 2, 2010 08:20 AM
nick17
Nov 5, 2009 08:59 PM
redline380
Jan 3, 2009 08:53 AM
viper771
Dec 3, 2005 07:38 AM
