Headlight replacement 2000 a6
Old Sep 25, 2017 | 06:46 PM
Tony Ennis's Avatar
Default Headlight replacement 2000 a6
Hello I was looking to replace my headlights on my 2000 avant with factory HIDs... All lights I have found say they aren't compatible, any links or tips would be appreciated
Old Sep 25, 2017 | 06:52 PM
twopedalwarrior's Avatar
Any pre facelift factory a6 hid headlight will work. Literally plug and play. But it is hard to find them in good shape, the leveler mounting tab have been broken in the ones I've found.
Old Sep 26, 2017 | 08:54 AM
Tony Ennis's Avatar
I was looking to go aftermarket for a different look would I have to rewire everything and get away from hids?
Old Sep 26, 2017 | 01:00 PM
Aftermarket is fine, but you won't be able to use the stock wiring with out running a relay for the HID ballasts. The stock ones are plug and play
Old Sep 26, 2017 | 08:27 PM
Tony Ennis's Avatar
Yeah it came stock with hids but I wanted to convert it back sorry
Old Sep 26, 2017 | 10:41 PM
you'll have to run a hid harnesss for the other set, then itll work
oldmots
Apr 24, 2012 05:53 PM
slvr_S4
Oct 8, 2007 06:55 PM
Influentialstylez
Mar 29, 2007 04:30 AM
rkohan
Mar 20, 2007 04:16 AM
