headlight washer cap problem
Old Mar 1, 2014 | 09:55 AM
S54LR's Avatar
Originally Posted by aspen79
It appears you need a new headlamp washer assy and a cover. Think they were like $225 (at the stealership) plus the cover, plus painting the cover. From what I recall, it cost more to have the cover painted than the cover cost itself.
In the meantime, if you can access it, unplug the headlamp washer pump. The windshield and headlamps have separate pumps on the reservoir. That way you won't run the reservoir dry every 2 minutes.
Know what you mean, we've been having W/S washer weather here too (northcentral WI). Damn road salt.........................
That is awesome info. Thank you. Do you know how to access the pumps? Also, how easy is to replace the assembly? Do I need to remove the whole front end/bumper etc I assume? Is it even worth it?
Old Mar 2, 2014 | 09:46 AM
aspen79's Avatar
If memory serves (IF) they're behind the left front tire, inside the fender. Need to pull the fender liner out for access. The headlight washer pump should be the one with the bigger hose.
The easiest way to change the nozzle is pull the front bumper cover off. They come off fairly simple.
Old Mar 3, 2014 | 08:41 PM
S54LR's Avatar
Thank you. That is awesome info.
mcanedo92588
Jul 1, 2013 11:27 PM
SloRide
Feb 24, 2008 02:42 PM
dmelkmo
May 26, 2007 06:54 PM
dezithug
Aug 9, 2006 12:56 PM
CBing
May 15, 2005 01:12 AM
