Headlight washer sprays
Old Feb 7, 2010 | 07:04 PM
jj2345's Avatar
Default Headlight washer sprays
I know there not important but I've been determined to get these things working,lol
now I purchased a headlight washer pump from Audi,It was a pain but I installed it today but now only the driver headlight side sprays water the passenger side come up but nothing comes out.what could be the problem
Old Feb 8, 2010 | 07:49 AM
TwinTurboC5's Avatar
Default Headlight Washer
Hi,
Did you check the fluid line leading to the washer nozzle to make sure that the line is not blocked, plugged, pinched or that the nozzle itself is not clogged with debris?
Old Feb 8, 2010 | 05:15 PM
ppgoal's Avatar
I think you're wasting your time. My A6 headlight washers started leaking badly around 45k and I replaced both pumps, then it started again. Clamped them off. Bought a used A4 two summers ago -- same problem, same solution. The washer dumps too much water, anyway.
Old Feb 8, 2010 | 06:24 PM
jj2345's Avatar
Fixed the problem!!
The washer bottle didn't have enough fluid,and they work on water pressure so now it's fixed,thanks alot fellas.I'm a happy man
Old Apr 1, 2011 | 01:29 PM
GuyN3xtD00r's Avatar
Originally Posted by jj2345
Fixed the problem!!
JJ, do you have a write up on how you replaces the sprayer assembly?
mcanedo92588
Jul 1, 2013 11:27 PM
schiu
Oct 9, 2009 10:46 PM
Nardo
B8 Models
Sep 15, 2008 03:49 PM
Quaberto
Sep 20, 2006 10:08 PM
cdnskier
Jan 7, 2006 11:12 PM
