headlights
Old Feb 23, 2007 | 11:13 PM
kevnew's Avatar
Default headlights
I have a 99 A6, how do I tell what kind of headlights I have Xenons or halogen. Also the manual adjuster is broke does this mean I have to new assembly.
Thanks
Old Feb 25, 2007 | 10:48 AM
kevnew's Avatar
Default RE: headlights
anybody?????????????????????????
Old Feb 25, 2007 | 08:31 PM
slee22's Avatar
If you have xenons there will be a little silver box with a "Danger High Voltage" sticker on it, attached to back of the headlight cover (this is the ballast BTW). As for the adjuster, you probably will have to get a new assembly...if yours are yellow and hazy that might not be too bad.
Old Feb 25, 2007 | 10:17 PM
kevnew's Avatar
Thanks slee22
Old Feb 25, 2007 | 11:19 PM
auditech79's Avatar
Yeah and if you buy a new assembly you won't be able to adjust them without a scanner because the headlights have to learn the position, even if you adjust them the vertical headlamp adjustment module will re-set after you cycle the key.
Old Feb 26, 2007 | 11:41 PM
kevnew's Avatar
What kind of scanner is needed auditech79
PSULion21
Mar 18, 2012 11:28 PM
ashulga
May 7, 2010 03:40 PM
ashulga
May 7, 2010 02:56 PM
A62dot7turbo
Jun 27, 2009 10:17 AM
mschwister12
Feb 4, 2008 11:40 PM
