headlights
If you have xenons there will be a little silver box with a "Danger High Voltage" sticker on it, attached to back of the headlight cover (this is the ballast BTW). As for the adjuster, you probably will have to get a new assembly...if yours are yellow and hazy that might not be too bad.
Yeah and if you buy a new assembly you won't be able to adjust them without a scanner because the headlights have to learn the position, even if you adjust them the vertical headlamp adjustment module will re-set after you cycle the key.
PSULion21
Mar 18, 2012 11:28 PM
ashulga
May 7, 2010 03:40 PM
A62dot7turbo
Jun 27, 2009 10:17 AM
mschwister12
Feb 4, 2008 11:40 PM
