HELP!!!
Old Jun 15, 2008 | 03:15 AM
99A6WV's Avatar
Default HELP!!!
OK I was going to change the rear control arm on the front suspension on the driver side tonight. Well i ran in to a problem, i can't get the pinch bolt out. I've done the other side before and it went fine, so i have an idea of what i am doing. I have tried EVERYTHING torch, PB blaster, punch + 2 pound hammer, i mean every thing. Just wondering if my only next option is to drill it out? I also have the idea of saying screw it and just getting a salvaged knuckle and changing it b/c i think my bearing is going bad too. Any ideas are welcomed and thanks in advance...Also, I apologize for the horrible grammar, but it is 3 AM and I'm quite perturbed.
Old Jun 15, 2008 | 06:42 AM
Baskin 4.2l's Avatar
Default RE: HELP!!!
That is the biggest PITA. Given the year of the car and the years of build up it is going to be ab chore. I used a air hammer with a chisel on the end go straight in at it. That did it for me
Old Jun 15, 2008 | 03:48 PM
beng's Avatar
Default RE: HELP!!!
My pinch bolt was also frozen, had to actually drill the length or it to get it out, not an easy chore as I had to be careful not to go off center and damage the sides.MYair hammer would not budge it! GOOD LUCK BENG
