Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If replacing the hazard switch doesn't work i have found that the turn signal stock commonly shorts out the hazard relay from diverting electrical current. So after you replace the hazard/turn signal relay and you still hear the buzzing noise, disconnect the relay and replace the turn signal stock, this should fix the problem.
As for the right rear turn signal, i think thats just a burnt out bulb.
