Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 23, 2008 | 08:28 PM
jzstuggie's Avatar
Default Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
There is a high pitched noise coming from under my dash w/e I turn my right signal on. And the signal does not pulse.WTF!?!!?!!?
Old Sep 23, 2008 | 09:39 PM
ryuuoh's Avatar
Is the sound coming from the emergency flasher switch?
Old Sep 24, 2008 | 01:21 AM
jzstuggie's Avatar
I believe so. Also I just noticed my rear right signal turn does not seem to be working. Even when I press the alarm button the rear right signal does not flash
Old Sep 24, 2008 | 03:14 AM
auditech79's Avatar
If replacing the hazard switch doesn't work i have found that the turn signal stock commonly shorts out the hazard relay from diverting electrical current. So after you replace the hazard/turn signal relay and you still hear the buzzing noise, disconnect the relay and replace the turn signal stock, this should fix the problem.
As for the right rear turn signal, i think thats just a burnt out bulb.
Old Sep 24, 2008 | 12:29 PM
jzstuggie's Avatar
Where is the relay located?
Old Sep 24, 2008 | 12:42 PM
oc_audica's Avatar
^^ the hazard switch is the relay
