Help! ABS issue
Old Dec 23, 2008 | 08:52 PM
  #21
Chicagoaudi98's Avatar
Member
Originally Posted by hxgaser
Autozone scanner only reads CEL light information and may not read all VAG trouble code info.
Good to know, thanks Hx.
Old Jan 3, 2009 | 01:16 PM
  #22
Member
I was wrong! My wire to my drivers wheel sensor snapped. I spliced and all is fine. Thanks for all who told me not to jump into thinking the module is bad.
Old Jan 4, 2009 | 01:32 PM
  #23
sidespar's Avatar
Yes. Always check the wheel speed sensor first. You do this by reading vag-com codes for the abs system. The autozone odb2 scanner will not read these codes. Keep in mind that a bad abs module will throw wheel speed sensor faults too, but you won't be able to communicate with the module if it is bad. If you can communicate with the module, then it is good.
Old Jan 6, 2009 | 01:22 AM
  #24
Member
Thanks Sidespar. Appreciate the in depth explanation. Thanks to everyone else who let me know in this thread.
Now another question. My brake pedal is vibrating when I'm going slow and hitting the break lightly what could that be an indication of?
Old Jan 6, 2009 | 01:36 AM
  #25
chefro's Avatar
You may need to check your rotors or brake pads, if everything else on the front end is ok.
Hard braking warps the rotors in time, or sometimes defective pads from manufacturingf cut channels on the surface of the rotors. If sanding both does not alleviate the symptoms, you look at getting new rotors/pads.
Old Jan 7, 2009 | 12:10 AM
  #26
Member
My rotors def do not look right. Thanks for the info.
Old Jan 7, 2009 | 09:41 AM
  #27
sidespar's Avatar
Rotors don't warp. Common myth. Instead, they get uneven pad deposits. See here: http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Old Jan 7, 2009 | 12:24 PM
  #28
hxgaser's Avatar
Whatever the terminology is, you need new rotors and brake pads. Follow the bedding process from Stoptech website.
Old Jan 9, 2009 | 02:41 AM
  #29
Member
Thanks for the info. I'll get started on that soon.
nelson0639
Dec 8, 2014 04:44 PM
hotswaps
Aug 8, 2013 05:50 PM
hotswaps
May 27, 2013 07:02 PM
Dallas09
Feb 14, 2009 05:08 PM
poloblue67
Jul 19, 2006 12:28 AM
