help with Camshaft Position Sensor (G40) Open or Short to Plus
Old Aug 24, 2008 | 11:41 AM
beemerfanatic's Avatar
well.. the camsensorfault is still there... what else can it be??
Old Aug 24, 2008 | 02:42 PM
auditech79's Avatar
Did you do the timing belt using the cam lock bar? The timing is still off.
Old Aug 24, 2008 | 02:51 PM
Angry
strange... i used the right tools for the job.. cambar 3391 and T.D.C bolt 3242.
can it be the chain in the back of the top?
if i took out the bolt that's holding the cam weel,how do i get the cam back in place?need tools to set it right?
the car is not stable in idle either...
Old Aug 25, 2008 | 02:41 PM
can it be a bad Timing Chain Tensioner that makes the problem?
how can i se it on wagcom?
Old Aug 25, 2008 | 06:19 PM
auditech79's Avatar
You can't really check the tensioner with the vag com. You can check the timing of the tensioners if you want to, but it can't move un-less you took it out. On the other hand if its bad it can cause this problem, but the engine will usually sound like a diesel if it is.
Here is a diagram of how the tensioners are timed.
Old Aug 26, 2008 | 12:18 PM
tnx! i will try to see if the sensor is default first..
Old Aug 29, 2008 | 01:03 PM
Angry
well.. the code is gone now.. the timeing was of.. to bad,though.. the bolt that hold the cam weel has been tighten to hard by a son of a (#(/#(!")#`!)"#`#!(`¤(`"``???=&%=)/(/("//!!!!!!!) the last time..!!!!
Thanks to that i have to by a new camshaft!
Old Aug 29, 2008 | 02:02 PM
  #18
oc_audica's Avatar
I'm actually thinking mine might be the tensioner as well... really need to get it looked at (i haven't thrown any cel's but i definitely got the diesel chatter going on, and for a good year at least)
Old Aug 30, 2008 | 01:35 PM
  #19
do you have the same code on your car?
Old Aug 31, 2008 | 06:36 PM
  #20
oc_audica's Avatar
actually never got 1 code for this problem that is partly why i never fixed it... don't know wtf for sure
