HELP! Intermitent ABS /Brake Light
Old May 13, 2007 | 10:47 PM
rink2rink's Avatar
Default HELP! Intermitent ABS /Brake Light
I have a 1999 a6 that is about to drive me nuts- I have an check engine light has come on for about a year and the dealership says with the code it is giving they can't fix it till it breaks completly because it is a secondary air error 0411 and I'm also getting a 0441 EVAP emission control purge.....ANY IDEAS?? WELL....my newest issue is the ABS/brake light is coming on and off and I have NO idea what to do or what it could be. I am really hoping someone can help. I'm all ears to any suggestions. Thanks so much for any help
Old May 13, 2007 | 11:03 PM
SSn's Avatar
SSn
Default RE: HELP! Intermitent ABS /Brake Light
ORIGINAL: rink2rink
I think I had this one, it's bad purge valve =)
Dealer is jerking with you, BS, they don't have to wait for things to go south completely to fix it.
As for the brake light, don't know, mine started to come on too resently,.. [&:]
edit: use search for your codes and ABS... I've read something about abs module fix we might need to do.
Old May 13, 2007 | 11:13 PM
rink2rink's Avatar
thanks- I will check into the purge valve...I was begining to think the abs light issue was a wheel bearing from some posts...but the more searching I do the more confused and worried I am. UGH!!!
Old May 13, 2007 | 11:15 PM
SSn's Avatar
SSn
I did not really went into fixing my abs yet, because I'm using different car, but first thing I'm going to check is abs sensors at wheels (to make sure connection is good. Then I'll look around the abs module itlsef.
It should have nothing to do with wheel bearings
Old May 13, 2007 | 11:22 PM
rink2rink's Avatar
where are the abs sensors located? I thought from what I had read they were part of the wheel bearings
Old May 14, 2007 | 08:32 AM
SSn's Avatar
SSn
No.. ABS sensor is one of the ellectrical plugs mounter on the strun (in the front) there is two plugs I think, one of those is abs.
abs can turn off brakes on one or more wheels while stopping the car, it has no idea if you have a bad bearing or not =)
ricomilion
Jul 31, 2012 10:01 AM
blanthony
Mar 25, 2006 01:18 PM
