help with MAF sensor
Old Nov 22, 2008 | 05:51 PM
blazinhaze609's Avatar
Default help with MAF sensor
my computer keeps throwing a code from the MAF. Should i clean it and try and keep it? Buy a replacement? Or just get a different kind and if so which would you recomend for my car.
2000 audi a6 2.7t six speed
Old Nov 22, 2008 | 08:07 PM
marcb0127t's Avatar
DO you have a fairly new K&N panel filter by any chance? sometimes they come pre oiled too heavily and that can cause the MAF to throw codes...If this is the case, try a new filter...Even if you dont have the K&N, and you want to clean it, I havn't done it myself, but I know people that soaked it in rubbing alcohol while inside a bag, sook around for a little bit, let dry out and that will do the trick if its just dirty. If you try these things and it doesnt work, dont be quick to replace it...I had a MAF code and it took forever to figure out why..I replaced the sensor, still threw a code, the problem was a loose clamp on one of my turbos. Also , check the placement of your air filter, panel, or cone, to make sure there are no openings and to also ensure if its a drop in panel filter, that its sitting flush, and all the way down in the airbox.
Let me know how you make out..
Old Nov 22, 2008 | 09:27 PM
joetm's Avatar
electrode cleaner ... leaves no residue works the best
Old Nov 23, 2008 | 05:14 PM
Legaumais's Avatar
Default use a specific product of cleaning
Hello,
use a specific product of cleaning MAF
Old Nov 24, 2008 | 11:15 AM
hxgaser's Avatar
Try cleaning the existing one. It is whole lot cheaper than a new one.
Old Nov 24, 2008 | 11:18 AM
AutoUnionFan's Avatar
+1 on cleaning the MAF sensor, replacement is not cheap
Old Dec 13, 2008 | 08:14 PM
crazyguy's Avatar
Be careful with the MAF sensor cleaner, the stuff will eat at plastic if not used properly.
neomaxddr
Apr 1, 2009 03:16 AM
