Help with my brakes (2004 2.7T)
Old Jul 22, 2008 | 03:20 PM
massboykie's Avatar
Member
Default RE: Help with my brakes (2004 2.7T)
ORIGINAL: jaymac
will I need to siphon/remove brake fluid as mentioned, or should it be fine when compressing the pistons?
Hey JayMac
You canopen your brake fluid reservoir cap, and keep an eye on the level as you are compressing the piston. I would suggest bleeding a little fluid out so the old fluid sitting by the caliper is replaced with some fresher stuff. It is recommended to flush the system ever 2 years I think. Just an FYI...
If memory serves I think the carrier bolts are 17mm. But check the doc to make sure.
Cheers
Massboykie
Old Jul 22, 2008 | 04:01 PM
jaymac's Avatar
Thanks again for your help!
-Jeremy
cudafish
Jan 6, 2014 10:47 PM
maxxstl
Mar 22, 2008 01:15 PM
bnyaudi
Mar 15, 2007 02:02 AM
GTMA4
Jul 25, 2005 03:08 PM
