HELP NEEDED ASAP A6 2.5tdi CVT judder
i just bought an A6 2.5tdi with the CVT gearbox on test drive it appeared fine however driving it all weekend it seems to have a slight judder when changing gears especially when driving gently - when in tiptronic this problem is not apparent - when driven hard in auto the judder is worse almost like a misfire, i have read various horror storied on forums and do not wish to waste money at audi - how can i improve/fix/diagnose this problem and prevent any damage to car? will changing gearbox oil improve or worsen condition? please anybody reply with advice i am skint and not mechanical at all ;( thank you people - tip: DSG box much smoother
1st thing is scan the transmission for codes.
2nd give the TCM a reset by disconnecting the battery for a couple of hours.
3rd change the transmission fluid and hope it helps.
When your gear selector is all highlighted, the PRNDS or PRND432 means its time for a rebuild or replacement.
Yes a diagnostic. But a regular tool will not be able to communicate with the TCM (tranny control module). You will need a vag-com to scan the TCM for codes.
ok i did the diagnostic their were 3 faults found
18149 clutch pressure adaptation - limit reached - intermittent
18161 tiptronic switch (f189) implausable signal - intermittent
18226 - pressure control value 2 (n216) electrical malfunction - intermittent
they cleared codes test drove and then changed oil in gearbox - i drove car home and is now worse than before
