Help with replacing broken oil pan
Driving yesterday I head impact on the oil pan, oil leak out but I park my car immediately after accident. Is it hard to replace oil pan and what is procedure.
Help please
Max
Help please
Max
There's another topic with the exact same problem you have.
It should be a fairly easy job, although some of the pan bolts are screened by chassis' support transversal beam. You'll probably have to use some combination of wrenches.
Drain the oil, unscrew the bolts, lower the pan, seal the new gasket ("lower pan gasket" is the part you're looking for) on the new oil pan and mount it back. Add fresh oil and you should be good to go.
As said in the thread, you can find a new oil pan (I believe FCGroton -sells them via that route) on Ebay for $ 60.
derZeck
Feb 22, 2012 02:53 PM
EvanF
B7 Models
Jun 23, 2010 04:41 AM
paintballcs
Dec 23, 2009 08:26 AM
