My car is broken. I need some help, please
Old Apr 22, 2006 | 01:34 AM
elvis12's Avatar
Default My car is broken. I need some help, please
i had put up a post yesterday about missfiring.
well i have some new info...
first the car
1998 a4 1.8t fwd 150hp stock
tap stage 2 chip
2 stage BOV
k and n intake (no box)
custom exaust
here are the codes
16684 (random misfire detected)
16687 (cycl #3 misfire detected)
18021 (MIL Call-up - circuit open or short to b+) now this one happend after i put the test computer in that TAP sent to try and see if it was my ecu. it never came up on my ecu
here is what i did
1. moved all the coil packs around to see if it was bad and moved to another cylinder...it did not, stayed on #3
2. moved the injectors around to see if it moved to another cylinder...it did not stayed on #3
3. comperson test...all 125psi car has 80,000...that is good
4. changed all the plugs
what else could it be?
the (sorry for the lamens term) the thing that came out of the air box with the heat sink?
help please
E
Old Apr 22, 2006 | 03:25 AM
fastmayte's Avatar
Default RE: My car is broken. I need some help, please
maybe the ecu?
try this
take out the coil pack, see there there's actually spark on 3 coil pack while the car is running. also listen to teh injector on 3, see if it's clikcing. if no spark or no clicking, maybe wiring or computer.
Old Apr 22, 2006 | 03:28 AM
elvis12's Avatar
tap sent a test ecu, and it was the same, i did move the packs around, and pulld the wire on 3, with no change, and there was if i pulled another..
injectors all sound good, and when i puled the rail they were all shooting
humm
E
Old Apr 22, 2006 | 04:22 AM
elvis12's Avatar
wiring, that's what i think it may be too
thanks
E
Old Apr 22, 2006 | 01:23 PM
dankhound's Avatar
Ignintion control module on the airbox.
Old Apr 23, 2006 | 04:49 AM
victor_c's Avatar
yeah.. absolutely the ignition control unit.
some will call it Ignition Control Module.
ICU / ICM is on the air box... attached with 2 screws... it also use some thermal paste.
I had mine replaced a few months ago.
may be coincidence but my problem was cyl 3 too.
good luck
Old Apr 23, 2006 | 12:19 PM
elvis12's Avatar
i orderd it last night....i hope that is it.
i will be shur to let you guys know, what happens..
E
Old Apr 25, 2006 | 06:45 PM
elvis12's Avatar
well it was the ignition module
i replaced it with an aftermarket part from HUCO...is that ok???
also i am getting a coolant code
16502 or p0118(engine cooanl temp circuit -high input(low temp)
would that part make the car run soft? it feels like it has no boost????
thank all of you with the help on the ignition module
E
derZeck
Feb 22, 2012 02:53 PM
paintballcs
Dec 23, 2009 08:26 AM
deek
Apr 22, 2007 06:00 AM
mjvss21
Nov 29, 2005 01:19 AM
