Help with Serpentine belt tentsioner replacement
Old Mar 30, 2008 | 07:20 PM
galenishman's Avatar
Default Help with Serpentine belt tentsioner replacement
Hello! can someone please give me a hint about removing the serpentine belt tensioner assembly on a 2002 A6 with 2.7t???
Is their is a bolt through the center of the tensioner that holds it place or not??? It looks like you replace it as a whole asembly..Hopefully someone can help out.... Thanks!!!
Old Mar 30, 2008 | 08:08 PM
toolagit2qwit's Avatar
Default RE: Help with Serpentine belt tentsioner replacement
Try this link- it's an Audi DIY wedsite and it shows how to replace a timing belt on a 2.7- maybe it will give you some ideas-
http://www.audidiy.com/c5a6.html
Old Mar 31, 2008 | 07:27 PM
RedShoeRider's Avatar
ORIGINAL: galenishman
There was a thread about this a little while ago, so a search should prove fruitful....
However..
Yes, there's a bolt through the middle of the tensioner. IIRC, it's a 10mm that's in fairly tightly. Take out the intake snorkel, pull out the auxiliary fan on that side and you'll have plenty of room to work (well, plenty by Audi's standards). Before you touch the bolt, however, make sure you release the tension on the serpentine belt, as it's likely to go flying if you don't. get a 2" or so breaker bar with a 18mm (I think it's 18) socket on it; that'll give you enough leverage so you don't kill yourself. Also, if you're planning on resuing it, make sure you pin it in before you remove it from the car. (Once you take out the fan, there's an ear on the rotating arm that lines up with a hole in the non-rotating part. Lay into the wrench until these holes line up, then stick a 4mm allen wrench though the holes. It makes like a lot easier later on if you're resuing it).
You generally replace the whole assembly. However, it's possible to source the bearings on the pulley and rebuild just the pulley, but it's not a terriably expensive part (about 80 bucks). I'm not sure of the torque value for putting the bolt back in; it's tight, but don't go apes*it on it....it's an alumimum block afterall!
-Red.
Timon
Jul 7, 2012 01:29 AM
Rodmar
Jan 27, 2012 05:05 PM
BaldySA
Aug 15, 2009 07:59 PM
mcintcmi
Jun 20, 2009 11:13 PM
97 Quattro
Jun 30, 2008 01:20 PM
