Help: Weird Heat/Ac Problem
Old Oct 8, 2011 | 05:14 PM
aki011's Avatar
Default Help: Weird Heat/Ac Problem
01 2.7t auto
ok so i turned on my heat last night and for a min it was kinda warm and then its gets cold as if i turned on the a/c. today i had the temp on high and it was like having the a/c on??? then i turned it down to low to see what would happened..still stayed cold but the car started to rough idle and the abs and traction light came on...i then turned it back up to high turned the car off and back on and the lights went away.
ive never experienced anything like this. i mean i know what its like if you need to bleed your system or something but its def not that plus i have messed with that at all. the car temp shows normal at all times. The fuse is fine..
im really stumped here..Any help would really be appreciated
Old Oct 8, 2011 | 06:30 PM
02A6Beau's Avatar
hrmmm.....
make sure if you want full heat you have your ECON button pressed. anything else and the climate control system tries to give you a "blend" of heat and AC.
the rest of your problem sounds like it may be the AC compressor. It runs off the same belt as the alternator so if your compressor pulley locks up and your alternator isn't getting "spun" properly, your voltage drops and you get loss of power steering, rough idle, abs and EPC lights followed by battery/alternator warning and engine shut-down (if the voltage drops low enough)
right now, just a guess based on the symptoms you described. it was the FIRST thing that came to mind. could be a whole host of other things too
-not an expert just an enthusiast
Old Oct 8, 2011 | 07:31 PM
bob martin's Avatar
ditto on the analysis and the qualification. Sounds like one for a indy repair guy.
Good luck,
Bob
Old Oct 8, 2011 | 07:44 PM
aki011's Avatar
thanks guys..yea i mean i thought maybe heater core hoses clogged? or the valve is messed up?
i dont know but its gonna get real cold soon so i gotta get this fixed..haha
Old Oct 13, 2011 | 09:43 AM
black sheep's Avatar
I have same problems exact today i'm taking my A6 2003 to the dealer to check it up and i will post it when I get it fix. thanks
Old Oct 14, 2011 | 12:33 PM
aki011's Avatar
blacksheep...yes please keep us updated as to what the problem was and the fix
thanks
Horvath12
Dec 28, 2012 07:50 AM
PLUGMUDD
Jul 12, 2011 07:06 AM
netoLopez
Feb 18, 2011 06:34 AM
mackman22
Apr 10, 2007 02:29 AM
audi_bos
Nov 8, 2006 05:57 PM
