How to manually reset sunroof
Old Jul 20, 2007 | 12:06 PM
Cloud2Ground's Avatar
Default How to manually reset sunroof
Left lights on and battery died. I jumped started my 96 A6 Quattro and the sunroof opend, windows and doorlocks stoped working. I put key in door, locked and unlocked it, that fixed windows and door locks but sunroof all goofy and won't close. I manully closed it and unpluged the switch (just incase). Is that enough, will it work right if I hook the switch back up (with switch in close position). Im afaid to try it as the sunroof manual crank is about to strip out (not sure if I will be able to close it again) and that would be very bad.
Thank you,
Don
Old Jul 20, 2007 | 12:22 PM
techbod's Avatar
Default RE: How to manually reset sunroof
press and hold the button till it opens all the way then the same for closed position that should store it to the memory
Old Jul 20, 2007 | 12:29 PM
The switch is not a button rather a pot.. So with that you mean turn the pot. all the way to open then close, starting in the close position...
One more thing, I just noticed my radio will not power on at all, fuse is good. I have the code but cant get the radio on to enter it. 96 A6 Quattro with Bose system.
Thanks again,
Don
Old Jul 20, 2007 | 12:37 PM
auditech79's Avatar
You need to change the potentiometer, or the **** you see on the roof. Its a common replace item and can make the sun-roof act wacky.
Diarmaid
B8 Models
Jan 31, 2011 08:51 AM
gordond
Jun 4, 2009 04:19 PM
Ziobrosis
Feb 24, 2009 04:22 PM
audifan1
Oct 3, 2007 11:35 AM
auto3251
Dec 5, 2005 06:14 AM
