I have a serious problem with my A6
Old Nov 26, 2006 | 07:09 PM
nexuspr's Avatar
Default I have a serious problem with my A6
Today I picked up my A6 99 2.8L 30v from my mechanic, Ive done an extensive work on it, Changed the timing belt, serpentine belt, water pump, thermostat, cam and camshaft seals, fixed an oil leak from the oil pan, added new oil, did a radiator flush, and my car had the CV joints and CV boots also damaged, changed all that also, added new front struts also, I arrived at home and the car was perfect running!!, nice and smooth. I wanted to give it a little test on my neighborhood, and just after leaving my home and running it for like a minute or so, The car started making a rattling sound and the steering wheel got very very hard, I just couldn't go any further. I parked it on the sidewalk and I turned it off, after like 10 minutes, I started the car and was doing fine, but right after I put the shift on drive, The car started making a very bad sound, and I couldn't move the steering wheel, I couldn't move it any further. I had to tow it back home. please any ideas, what it might be the problem???, Im calling my mecanic tomorrow morning to hear his point of view.
Old Dec 1, 2006 | 11:10 AM
dankhound's Avatar
Default RE: I have a serious problem with my A6
Check you power steering fluid level. Also check the serp belt tension.
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
