Identify the Oil Leak
Guys, the timing chain tensioner gasket and the half-moon seal are under the bolted in place timing chain tensioner. Like it or don't, believe it or not, unless you can produce Audi documentation which says otherwise, you MUST remove the tensioner (which also means removing the cams) to get at the gasket and seal.
